Files Print Different Sizes
We print directly to a printer and generate a pdf version as well using pdf plot driver file for both. Recently noticed that if I print the pdf version without opening it up in Adobe (right click on the file and select print) it looks exactly like the sheet printed directly from microstation and both are to scale. If the the pdf is opened in adobe and printed, it scales everthing down significantly (adds approximately 1/8" to the border offsets and scales the objects inside the border as well).
Has anyone experieced this?
Any help would be greatly appreciated.
EBS
