Modifie compression in TIFF driver
 I need modifie the default compression of TIFF driver from default:
; Specify the data compression technique.
; The default is LZW for color output, CCITTFAX4 for monochrome output.
;CmdName /appname="tiffDriver" /command="Compression" /qualifier="NONE"
;CmdName /appname="tiffDriver" /command="Compression" /qualifier="LZW"
;CmdName /appname="tiffDriver" /command="Compression" /qualifier="CCITTFAX4"
;CmdName /appname="tiffDriver" /command="Compression" /qualifier="PackBit"
;CmdName /appname="tiffDriver" /command="Compression" /qualifier="CCITTRLE"
to:
PackBit for color output, CCITTFAX4 for monochrome output.
How can I do?
Best Regards
Maurizio
  • I think you can' t do that, as v8 2004/XM printer driver for Tif files can't compress in Packbits. I use v8i for that. Neverless it is simple to convert them from LZW to Packbits later if needed.
    from tif.plt:
    ; Format = 3 tells the lorip driver to generate a TIFF file.
    ; Quality identifies the type of compression
    quality=1 ; Default compression
    raster_compression/format=3/methods=(0)
