Plot coming out upside down.
I was looking into different plot drivers for Microstation to try and consolidate them, I am trying to use the hpglrtl.plt file because it can print rasters good unlike the hpgl2 driver, but the issue I am having now is my 22x34 page is coming out upside down (it is landscape across the page) put would like it to be rotated 180 degrees. Is there a line I can add to the plot driver to rotate the drawing, have not tried to change the setting on the plotter which is at 0 for rotation, would like to change it at the driver.
Bryan
I tried the rotation at the plotter to 180 degrees and it did not change anything. Also tried adding a line of
rotate=180
and it gave me an error when loading the driver in Microstation.
