Oce TDS 700
My company just got an Oce TDS 700. I have been trying to create a plot driver for it. I have been unsuccessful so far. The only way I can get it to print from Microstation is to use the printer.plt driver to call the windows driver. It is very cumbersome. Does anyone out there have a 700 that they have a driver for.
I have tried a driver from one of our other offices that has an Oce TDS 600. They have no problems sending prints directly to the 600. When I try to use the driver Microstation says it is an invalid driver and will not load it.
  • I have a new problem. Everything is printing fine with this driver. However, I want to be able to write a driver that pulls the paper from 1 specific roll all the time. Since our OCE printer has 4 rolls I would like to make roll 4 mylar instead of regular paper. I have tried to define roll 4 in the plot driver but it is being ignored. How do I get the driver to pull from roll 4 only.  Below is the line that defines the printer parameters.
    sysprinter /name="\\engdat1\3rdProduction_TDS700" /form="34in Mylar" /orientation=landscape /offset=(0.0, 0.12) /unit=in /tray="Roll 4"
    OS Windows XP
    MS 08.05.02.70
    OCE TDS 700 plotter
    Mike
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
Reply
    OS Windows XP
    MS 08.05.02.70
    OCE TDS 700 plotter
    Mike
  • In this thread, How to print using HPGL2 plotdriver?,  I posted a copy of my KIP6000.pltcfg file which is a modified copy of pdf.pltcfg that copies the output directly to the shared KIP 6000 printer.This allows us to use pdf.pltcfg to create pdf archive files which look exactly the same as prints sent directly to the printer. You can edit any pltcfg file (search help - Printer Driver Configuration dialog) you can define pre and post exicute commands (search help - Define pre-print and post-print program commands). The xml code I shared is part of our kip6000.plt6cfg file which is an example of how to copy the file $(MS_PLTOUT) to the printer \\kipstf\KIP6000. If your Océ TDS 700 can support postscript printing this should work for you also.
    HTH - Roy
