Are you checking the printing preferences?
Click on the Configure Printer icon and then click on the Preferences button. Our Bizhub printers have no way for individuals to save these preferences, but in each session, they can be changed and used again.
I suspect that your settings are set to output 8 1/2 X 11 instead of same as original.
They may be saved in a session. So after setting them with the apply button but not printing you may be able to use batchplot.
However, if not, can you batch plot to PDF where all sheets are in one PDF and then simply print the PDF?
