Hi! I'm using a Bentley plt driver rather than a Windows print driver. When I send plots to a particular printer, in which in this case it's the HP Z6100PS plotter, the vector lines are plotting transparently, (i.e a red line and blue line when crossed, produced a purple line...)
Has anyone experienced this with the HP Z6100PS? Is there a way to toggle this off? Thanks!
What 8-digit version (i.e. v##.##.##.##) of MicroStation are you using?
Try changing the Merge setting in the printer to off. The Merge setting controls the treatment of overlapping lines in an image. On the printer, Merge has two settings Off and On.
From the front panel of the HP Z6100ps printer chose the icon that looks like a small printer, then select Printing preferences > HP-GL/2 options > Enable merge > Off
HTH
Jeff
