Problem plotting embedded raster type 87
I'm having difficulty plotting a MicroStation file with an imported raster file.  We do not have the raster file, just the MicroStation file, it's attached.  The raster plots with a black background and we need it to plot with a white background.  In MicroStation the image displays the way we want it to plot.
In our plot driver file we use the hardware_raster record with /background= option.
If we leave the /background option off the image is inverted from what we would like.
If we set the /background option to black the image doesn't print.
If we set the /background option to white the image is inverted from what we would like.
If we set the /background option to color the image doesn't print.
This is using a bentley hpgl/rtl plot driver, which is attached.  When using the bentley pdf driver, no matter the setting of /background the image plots correctly.
I must be missing something. Any help is appreciated.
Also, I usually can select an embedded image in MicroStation and use Edit>Copy and paste to a raster editor, but it doesn't work for these images, (we have a few MicroStation files with these embedded images). If I can save the images, I can attach using Raster Manager and get better results.  Any suggestions with that would also help.
Thanks.
MicroStation version 08.05.02.70    Windows XP Pro version 2002 sp3
iis02_01.dgn
Parents Reply Children
