I am trying to print a plot that is 36" x 264" to a pdf I have the ability to select the paper size that i need but it only plots 200" when i see the pdf.
I believe the 200" is a Postcript page size limitation. I've never been able to create a PDF page longer than that.
Jim
The 200" size limitation was a limitation is PDF. Using MicroStation v8i or later, you can set the PDF Version to Adobe 8 (PDF 1.7) in the pdf.pltcfg to create larger size PDF files.
