Batch Plot issue
Batch plotting has worked fine, but, about two weeks ago, started loosing specifications.  Able to create new specifications, but they will only work for that session in Microstation.  I'm at a complete loss.  Any ideas to fix problem would be appreciated.  Thanks.
MicroStation Version 08.05.02.35 Windows x86
  • You should move batchplt.spc out of the system folder. Every time you install new versions of Microstation the System directory gets over written. We placed ours on the network so everyone has access to it. Then you can point Microstation there. We have several batchplt.spc out there because we work for several state DOT's. The only time I've lost specifications was if the file or folder was set to read-only or I have noticed there seems to be a limit to the number of specs defined in each file. I do not know if that is true or not but, after I have so many defined, I can not add to what is there. Are you sure you still have write access to the location of your batchplt.spc file and folder???
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
