PLT Default Print-To Directory
I know that I can force Microstation to print to a certain filename / location with:
default_outFile /auto_overwrite = "C:\TEMP\$(basename(_DGNFILE)).pdf"
But what if I want the printer icon to open to a specific folder and then allow me to name the file?
Could I use the same : default_outFiel/auto_overwrite and just leave out the file name? Or does that screw things up?
  • In the following urls the following conventions are "generally" used:
    00000 = the Page #, which is not set anywhere but in the DGN name (ie, 00233sd.dgn = Storm Drainage #233).
    xx = Discipline (sd=Storm Drainage / Stormwater, ba = Base, wa = Water, etc.)
    Here are the paths for STORM prints (Storm Drainage / Stormwater)
    CGM : H:\scratch\07plots\storm\sd-next-distro\CGM\00000xx.dgn
    LRG : H:\scratch\07plots\storm\sd-next-distro\Large\00000xx.lrg
    What I would LOVE would be a parser in the PLT file. Then I could parse the filename of the DGN I am printing. Since the variables incorporated by our system are only for system-specific and not user-specific purposes. I have a list of vars, but they point to folder that we (as end users) rarely, if ever, touch.
    Does that help?
    It's all just lines and dots right?
    Rev. Brian Scott O'keefe
    ( www.randomblink.com )
