Created new levels on my file but are not displayed after I print to PDF
I created a few new levels on my working drawing, so it makes things easier for editing......
but when I print the file to PDF, the PDF file does not display the lines I drew with the new Levels. All the Plot are checked on.
Any ideas how can I get my new levels to print? or do I have to stick with the existing levels?
  • Please check if the following solution can fix your problem:
    ***Snip***
    A PRINT INI (*.ini) file was being used. It had been created prior to certain levels being added and therefore those changes were not being seen. To correct problem open Print Menu and choose Settings>Update from View ... then re-save .ini file (Configuration>Save) to save those new changes.
    ***Snap***
Reply
    ***Snip***
    ***Snap***
