Sheet numbering with Batch Print
I'm not sure how to phrase this question, so I'll explain what I need to do and maybe there's someone who can help me accomplish the task.
I want to link a text substitution, to a spreadsheet or text file, that would provide the sheet numbers to the plan sheets when they Batch Print.
I have a civil roadway project of about 500 sheets and a spreadsheet with path and filenames; all sheets use a common border reference file; each sheet is in a single .dgn file; we use Batch Print with a pen table to text substitute the filename, date, user & scale, and want to number the sheets when we print and edit the numbering at the spreadsheet.
All suggestions are greatly appreciated, DRL
  • There is no way you can do this with text substitution really. If you were to rename all your model names for your drawing model then you could use the model name is the drg number  and  the $modelname$ or similar could be used but how you rename each model without doing it manually... would require vba... you  could try the drawing file name  and  place a BG  fill mask in the border refererence file  to obscure the extension of the name  ie  drawing name.dgn  then you could download and  instal the free program bulk file rename utility and it will let you rename all you file drawing names to a sequential number scheme  of you choice say for example CIV100.dgn then  you can get it to rename each drawing by  + 1  so all your drawing end up with CIV100- 499 in seconds you can rename the lot anything you want great tool...
    then in the border ref file  you use the text substitution $file$ ( or whatever for the short file name) use the text justifcation such that the DGN extension is always the same distance from the edge and  put a BG  fill over the extension and ensure its ontop  by the bring to front... now in theory the file name will be the drawing number and  will print under the  fill...
    Otherwise its tags and  you'll need to write your own export/ import tags from excel vba macro or very cheaply buy somethnig like caddpro title block manager from Adam Lambert  ( under $250 AUD)  or Flexitable from LA solutions (don't know price )  but either one will import and export tags from excel but you have to have the tag in the dgn first... I think you can put the tag in the ref border file then create a macro ( vba probably) to copy the tag from the ref file and place it in the active drg and use the batch processor... or maybe you could just make simple macro to merge the border ref file and its tag and batch processor that... ( this ones easier) then use the flexitable / caddpro  approach to import export the drawing numbers...
    once you got this in place you would only put the tags into new drawings  ie all the title block info should be tags copied  or placed into the live file... I use to have a  model with the tag set so it overlayed the drg border sheet then I merged it into the active but left the border sheet as a ref file... by the way Caddpro does that part automatically for you once you redesigned you board  title sheet file...
    I hope this was of  help
    Lorys
    click link to PM me
  • Good Day Lorys,
    I was afraid that my solution was going to be as you have explained. I work for a State agency that will not entertain any notion of spending for third party software. We are using a pen table & text substitutions to number sheets at this time. We have a code scheme and we maintain a database of drawing files; we assign a new code to each drawing created and organize the database in desired numerical order; then we renumber with a text editor that has column capability; after that... it's just a copy/paste operation into the pen table.
    Thank you for taking the time to respond.
    Sincerely,
    D.L.
