Hello,I've installed Microstation 2004 (08.05.02.70) on Windows 7, and have the next issue.When I try to print with printer.plt driver on a Ricoh Aficio printer, the lines with dotted linestyle (1-7) are printed as continuous.Anyone has the same problem? Is there any solution?
Regards.
probably the scale..try bumping the syles by a factor of 10 to see if it changes
I've solved it.
At the Ricoh printer preferences menu, there is an option at Print Quality submenu for swapping between Vectorial and Raster. The correct option is Raster.
