Dimensioning - When converting from V8.5 to V8.9
Hi, When i plot from V8.5 to V8.9, their are extra fields in the dimensioning dialog box for Centre > Left etc. When i plot running dimensions, the alignment defaults to centre justified. Is their a way to set the default settings to right justified for running dimensions only?
  • I'm not sure what "Center > Left" and "Center > Right" do, I haven't seen any difference in them, the text always comes in centered.  Maybe it is for some too(s) that I don't use?  Those options are not even listed in Help.
    You could define a duplicate style to what you normally use with a different justification or could create a button (or function key) that executes the keyin for the desired justification ("DIMSTYLESET FORMAT DIMJUSTIFICATION RIGHT") to quickly change between settings.  I have a dialog that I use to set various dimension and note settings without having to open the dimstyles dialog.
