Rasterized Plotting
I was wondering if anyone else is having problems printing transparent elements on large roll drawings.  I typically work on larger civil projects where we need to plot roll drawings of the project area. I wanted to use transparent shapes to identify various types of impacts while still being able to see the information below the shapes. However, when I rasterized my layout it took 15 min. and was only about 30% finished processing when I cancelled the plot.  Has any one else tried rasterizing larger layouts with larger amounts of data? Could  I be missing something in my plot config file?
Parents Reply
  • Element transparancy is a view attribute.  I believe the default setting of the view attribute initially comes from your seed design file.
    Raster transparency is a different topic, unrelated to the element transparency introduced in V8 XM.  Completely transparent raster pixels can be printed in non-rasterized mode (although inefficiently by most printer drivers), but not partially transparent raster pixels.  Partially transparent raster can only be printed correctly in rasterized mode.
