Prining Help File
I am trying ot print the help file to bind into a hard copy manual. The only way I manage is to print each chapter individually. Has anyone got a better way? I would like to give a single print instruction to print the entire helpfile, its index an its contents.
  • HTML Compiled Help
    HTML Compiled Help (.chm) files are common in Windows: most applications deliver help in this format. As you can guess from the name, a .chm file is little more than a collection of HTML files and images, compressed into a single file. As you've found, .chm help documentation was not designed to be easily printed.
    Since the .chm format is a Microsoft format, not a Bentley format, you would do better to ask your question on a web site that deals with .chm files.
    Unsurprisingly, many people have asked the same question. I googled for print .chm file and received several hits: this is the first hit.
    Regards, Jon Summers
    LA Solutions
    LA Solutions
Reply
    LA Solutions
    LA Solutions
