I am having problems with the colours of my files when trying to batch plot.
The same layers are used on varies drawings although it only seems to effect half of them. This is only an issue when batch plotting from my computer both to the printer and as a PDF, and also seems to be incorrect on other computers in my office.
I should also add that I have a DGNLIB file that has overrides for the yellow and green levels.
As you can see in the images below only one of the references is effected with odd colours and the other is fine this is only seen when viewed on my computer for batch plotting. When I print the files by opening each one individually there is no problem.
Below that is an image from another computer in my office and the colours are incorrect on screen and when printing/batch plotting.
If anyone could help I would really appreciate it as I have not been able to find a solution.
Thank you
(my computer screen while trying to batch plot)
(another computer in my office with the colours being incorrect on screen and when printing)
bit more info,
when opening read only, the colours set in the overrides change in level manager. Why would this be occurring?
Read/Write below
Read only below
Timothy Hickman
Main: 877 627 3772|
