Ustn v7 to v8XM --- changes to printed page size/margins?
We have a printer driver for the HP Laserjet 5000 PS that we have been using for ages for 11"x17" format printing of 22"x34" sheets (commonly called quarter size printing). It was setup based on the actual printed page's size, working in conert with our batchprint border to produce exact scaled prints using layout settings = "maximize" and offset = 0,0
The page size in the PLT driver is this:
size=(10.75,16.75)/num=4/off=(0.25,0.24)/name=11x17
Now my plots are not coming out to scale, roughly 95% too small.has anything changed in Ustn in recent times (To XM) that would add more margin space to the printed area?
; = Palmer Engineering, Cincy Office =
; = HP5000n Print Driver =
; = Should be used with Pen table - Date1.tbl =
; Postscript monochrome example Plotter Configuration file
; $Logfile: I:/mgds/plot/pltcfg/pscript.plv $
; $Workfile: pscript.plt $
; $Revision: 6.3 $
; If you change this file, please do not disturb the above source control
; information. It will prove useful in the event that a future release
; changes this file.
num_pens = 255 ; required record, must precede any "pen" records.
Vector_color_mode=grayscale
change_pen = both ; options are color, weight, level or both
model = postscript ; plotter model number
driver = pscript ; MDL driver to use
rotate=cw ; clockwise rotation
;autocenter ; Automatically center plot on page
;border/pen=1/filename/time/NOOUTLINE ; leave this out for no border
;end_plot=eject ; Forces a page eject on printer
default_extension/auto_incExt = '000' ; default extension for plotfiles
rtlsupport=1
rtl_max_plane=3
rtl_min_graylevel=65
; To configure a default output file name comment out the default_extension
; line above and uncomment this line. "lpt1" may be substituted with any
; desired filename - e.g. "$(MS_PLTFILES)plotfile.000"
default_outFile/auto_overwrite = "\\PEcinfs1\HP5100"
communication = (eol1=13,eol2=0)
; communication = (handshake=0,baud=9600,par=none,data=8,stop=1)
; This configuration file contains the necessary records for English
; and metric resolutions. English units are used by default. To use
; the metric setting, comment out all lines in the ENGLISH section and
; uncomment the RESOLUTION and SIZE lines in the METRIC section. The
; SIZE records define the plotting area of the page.
; ENGLISH resolution and SIZE records
size=(10.75,16.75)/num=4/off=(0.25,0.24)/name=11x17 ; leave room for border
;resolution(IN)=(0.003333333333333333,0.003333333333333333) ;300DPI
resolution(IN)=(0.001666666666666666,0.001666666666666666) ;600DPI
; Metric resolution and SIZE records
;size=(270,420)/num=4/off=(12,12)/name=TABLOID ; leave room for border
;resolution(MM)=(0.08466666666666666,0.08466666666666666); 300DPI
;THE FOLLOWING DETERMINES THE COLORS OF THE LINES
;PEN(0)=(144-239,241-255)/RGB ( 0, 0, 0) ; Plots Black
;PEN(2)=(36) /RGB (255,255,255) ; Plots White
;Refer to plotter color chart for colors of hues
PEN(1)=(1-39) /RGB ( 0, 0, 0) ; Plots Black
PEN(2)=(40) /RGB (220,220,220) ; LIGHT GRAY
PEN(3)=(41) /RGB (200,200,200) ;
PEN(4)=(42) /RGB (190,190,190) ;
PEN(5)=(43) /RGB (165,165,165) ;
PEN(6)=(44) /RGB (140,140,140) ;
PEN(7)=(45) /RGB (130,130,130) ;
PEN(8)=(46) /RGB (100,100,100) ; DARK GRAY
PEN(9)=(47-130)/RGB ( 0, 0, 0) ; Plots Black
PEN(10)=(131-132)/RGB (140,140,140) ; - odot v8 Minor Contours
PEN(11)=(133) /RGB (165,165,165) ; Plots Dark Grey - odot v8 Major Contours
PEN(12)=(140-253) /RGB ( 0, 0, 0)
PEN(13)=(254-255)/RGB (255,255,255) ; Plots White - For TextWash MDL
; Stroke_tolerance determines tolerance for arcs and circles. Value is
; between 0 and 10 with 10 being the greater tolerance. Larger values
; also create larger plot files.
stroke_tolerance=10
; The style records define how the design file line codes (styles)
; are to be plotted. Values are in plotter units (resolutions).
; Values determine pen down/up movements, where (10,28) for a dot
; pattern leaves the pen down for 10 units and up for 28 units. The
; /nohardware switch causes software stroking with these values.
; This example has the /nohardware option commented
; out, so the printer will draw the styles.
style(1)=(6,18) /nohardware ;style = dot
style(2)=(30,30) /nohardware ;style = med dash
style(3)=(60,35) /nohardware ;style = long dash
style(4)=(60,35,20,35) /nohardware ;style = dot-dash
style(5)=(18,23) /nohardware ;style = short dash
style(6)=(60,20,8,20,8,20) /nohardware ;style = dash-dot-dot
style(7)=(60,20,25,20) /nohardware ;style = long dash - short dash
; The weight line determines the number of strokes to use with each weight.
; The first position defines weight 0, second weight 1, third weight 2 and
; so on up to weight 31. To increase or decrease the number of stokes per
; weight, change the number in that position.
;MS line widths=0,1,2, 3, 4, 5, 6, 7, 8, 9,10,11,12,13
weight_strokes=(1.8,4.2,7.8,10.8,13.8,16.8,19.8,22.8,25.8,28.8,31.8) ;half-sizE ODOT
;weight_strokes=(3.6,8.4,15.6,21.6,27.6,33.6,39.6,45.6,51.6,57.6,63.6) ;FULL-sizE ODOT
; PENTABLE Record #
; Substitute the name of a pentable file to be loaded when this #
; driver is selected. #
pentable=Date1.tbl
; The record, hardware_raster, can be used to plot raster element
; types 87 and 88. Only black and white plots can be output.
; Color raster elements will be converted to black during plot creation.
hardware_raster/resolution=300
; for dense filling
pen_width(1)=2
linecap = 0 ; 0=butt, 1=round, 2=square
linejoin = 2 ; 0=mitered, 1=round, 2=bevel
miter_limit = 1.415 ; larger values mean longer spikes
; 1=none, 1.415=90deg, 2=60deg, 10=11deg etc.
; Construction/active points are not plotted by default. Uncomment the
; next line if you want points plotted. Points are plotted 0.1 cm dia.
; point_size = .1
; largest_polygon is used only for element filling. The value defines
; the point at which software filling takes over in place of hardware
; filling. The value relates to number of vertices used to draw the
; element.
largest_polygon=1400
