When printing to PDF in Microstation, I would like its 'File Properties' metadata autocompleted with the following:
- Title (ideally the drawing title off the title block, if present)
- Author (computer username)
- No of pages (usually 1)
It would also be GREAT if you had the option to add Keywords (for later searches)
I have tried the 'Provenance data' options in the printer configuration file without success.
Any thoughts? If I use the AdobePDF Windows driver installed with Acrobat the fields get filled in. But the Bentley driver is to be preferred.
