Does it display correctly in the Print Preview window of the Print dialog?
Same problem on 08.09.04.88 version. Is there a workaround for this?
Are the files 2D or 3D? If the latter, if you go to Settings > 3D Plotting, what is set for "Convert Wireframe Geometry" and "Convert Annotations"?
Hmm...should be 2D files, let me see if that is the issue.
