Pen Table - scale cells/linestyles
Is it possible to scale the cells and linestyles within a file through the pen table? I have some files with cells and lines at a scale of 1. This file gets referenced into different scaled sheets (1"=20', 1"=50', etc.). I was hoping to be able to scale the 1 reference file rather than upkeep 2 or 3 files with different scales. I believe Iplot can do this but it's not an option here. Any fancy way to do this or V8i? TIA
MS8.9.4.51
  • I have not tried this with pen tables. For the cells you can place the cells with annotation scale. You need to allow this in the cells model first and then use the option (the little slanted A-Button) in the cells dialog. In a scaled sheet the cells become scaled according to the given scale factor. For the linesytles I remember that there is another setting to scale them - though this is depending on the type of linestyle. You can find extensive information about this in the helpfile.
    Regards, Gerd
