We're creating DWF files from MicroStation XM using the new DWF Writer (v4) but the Arial font wont print correctly (see attached).
I note that this issue has also been reported on the Autodesk forum but I can't find any resolution tips. I was wondering if you've also picked on this and would be able to advise on a solution.
FYI, we didn't have the problem with DWF Writer v3 but unfortunately the new Design Review 2010 won't read these files properly...again the fonts are all distorted.
