Batch Printing : Rasterized : As-is
In the batch print display options there is a setting for Output mode that can be set to "as-is"
What determines the "as-is"? Is it if the view is set to wire-frame or not?
  • Thanks Andrew
    RE: "This default behavior may be overridden by specifying a default mode in the printer driver configuration file. "
    So if the .pltcfg is set to "No preference" the last setting actually used on a particular computer will be in effect. I assume that setting the desired value in the display options output mode will be the final arbiter of this setting.
Reply
  • Thanks Andrew
