PDF.pltcfg driver does not create PDF
I am trying to create a PDF file using the USACE's PDF-AECv3.pltcfg driver.  Everything sets up properly and then when I hit the Print icon.  Nothing happens.  Does anyone have any suggestions as to why this driver will not work?  I have also tried using the straight out of the box driver from bentley while still using the USACE dataset configurations.  This makes no difference.  I still get no PDF file.   Could there be a setting in the USACE's settings that creates a conflict with resources files?  Your urgent help on this issue is greatly appreciated.
  • When I hit the print icon.  It doesn't say or do anything.  Since this posting I have found a work around.  I have been selecting the Sys-AECv3.pltcfg file.  I then select a windows printer which is called PDF995.  This allows my to create PDF files.  But it would still be nice to understand why the PDF-AECv3 print driver does not work correctly.  I have attached the PDF driver for anyone's review.
    P.S.  I--O
    PDF-AECv3.pltcfg
Reply
    P.S.  I--O
    PDF-AECv3.pltcfg
