Setting up batch print specification
 I'm a newbe when it comes to Batch print and need some help.
 I have about 150 Microstation drawings that i need to plot.  Normally i would open the drawing, view it and plot it.  Yes, one at a time.  Now since i have 150 drawings i would rather just print them all out.
 I go into the batch print dialog box and add the all the files to be printed.
 I high light all the drawings and select the file>print and i get the print batch dialog box.
 in this area i select "Set up system printer".  I select my printer and then hit preferences and select my sheet size. "c"
I then select "ok" and it starts to print.
When it starts to print, the first sheet comes out exactly what i want.  However, all the sheets after that come out in the right paper size but only the lower right corner of the drawing appears.  I looks like it's printing 1 to 1 and want to have it print "scale to fit".
Any help would IS APPRECIATED!!!
THANKS!!!
Parents Reply Children
