Ok,
I am having a problem with a Microstation V8 XM file that containes both vector and 2 rasters, I am trying to create a pdf file then print a multi page pdf, but when I print the pdf that looks perfect the raster files are blacked out on a large format kip plotter, it prints fine on smaller 11 x 17 HP laser printer. Can someone HELP we have been beating our heads trying to figure out this one out?
Rynda
Rynda,
In Acrobat Reader, try printing using the "Advanced" Button (bottom left of print dialog) and the "Print as image" check box on the bottom of the "Advanced Print Setup" dialog. This works with the Windows KIP printer driver. You should not be having problems with PDFs submitted with Print Request.
HTH - Roy
