When I create pdfs everything looks fine but when I get redline comments back this problem always comes up. The logo doesn't look like others from different users and this logo is on every sheet. The image on the left is from the logo of a different users redline comments and the image on the right is what the logo looks like when I create the pdf.
I am the only one using Microstation while everyone else is using AutoCAD. I have a ctb file I'm supposed to use but that doesn't seem to work for me. I am desperate!
I am lucky to have this work. I work from home and upload my pdfs to an ftp site. I can do the work but if I can't resolve this I'm afraid I won't be asked to continue.
I hope there is a solution out there.
Thank you
This might prove to be a solution but I can't test it.. I assume that the logo jpg is the same provided to you as is provided to the others right. ok go to the Autodesk web site and down load the latest True view its free and it will simulate autocad for viewing and printing also get a pdf virtual printer driver like pdf995 or primo pdf these are also free and act like a windows virtual printer use google to find the free printer... .. now after you install the Trueview set it up to use the acad ctb you have been provided or ask for it again but for acad not converted for microstation
Now with true view open your autocad drawing you did in microstation and print it to the windows pdf driver eg primo and if you set the pent table correctly you should now have a pdf that looks exactly like your autocad rivals including the logo...
BTW are you and your rivals attaching the logo jpg the same way?
Could you get the company to give you a blank titlelblock with the logo attached the same way it is for your rivals ie is it pasted or is it xrefed as a raster.. this can cause problems .. I prefer the raster xref rather than copy paste this doesn't always work perfect for me either
Lorys
