Creating Large Small-Scale PDFs using MicroStation V8-XM
I am looking for better ways to create large small-scale PDFs that can be shared amongst the project team members.
I am starting out using the pdf.pltcfg - delivered with MicroStation V8-XM - and maintaining the default 600 dpi resolution.
We have corridor-type projects where the project managers want to review the current-status - in PDF format - of the entire 3-mile long project.
We are able to create a PDF by manipulating the sheet size - to a maximum of 200 inches x 200 inches.
This sheet size limitation (which I don't know if it is an Adobe limitation of the PDF driver limitation) allows up to create this PDF at approx. 1" = 1000' scale.
At this scale the image looks fine on the screen, but as you zoom in to check out different areas of the project, everything starts to look very blotchy and heavy - and illegible.
We would like to be able to create the PDF at 1" = 100' or even 1" = 50' scale..... which would be impossible for printing (on most all large format plotters) - but would allow the proper level of detail for zooming in and viewing specific areas of the project.
I have not experimented too much. I just figured I would ask this group for ideas.
David Allen
  • My experience with the plotter & pdf is maximum length is 5 m ( approx 200 inches long  )  and your  3miles=4.8km so based on the  metric  you should be able to create a custom plot sheet  5m : 5000m = 1:1000 max but  width is the  tricky  part  max paper physical is or real  42"  or  .82m  or  1000x = 4200"  or 820m so draw piece of paper 42"x200" and  scale it  up  1000 times and then use this as your  plot  boundary  but set you custom paper size to  42x200" or  in metric 0.842x5000m so for the  pdf the same  principle applies for  the 1:500 just  scale up the boundry  500x's and still use the same custom plot sixe
    Lorys
    click link to PM me
