Batch Print Specs Default settings
I have been adjusting some of the setting in my batchplt.spc through MS. When I start up a new .job file, the specs are pre-set somehow. How/where do I change this so that it will default to my desired specs?
When I start New, it opens with Xerox 8.5x11 spec. I want it to start with PDF spec. How can I change this? There doesn't seem to be any correlation as to how they are listed in Notepad.
Parents Reply Children
