PDF Creation in V8XM
I tried to create a PDF in Microstation V8XM with an attached Pen Table/ Design Script using the plt.pdf Bentley driver. The PDF was created but the pen table/design script instructions were ignored. Has anyone else had this problem?
  • Sorry, I thought you meant the pen table and/or pdf.plt were attached to your message.
     I use pen tables all the time without difficulty.  The only trouble I've had related to pen tables, is for batch printing, where they only seem to attach if I first load up the driver (which specifies the pen table) through the normal plot dialog.
     If you send your plot driver and pen table, I'll take a look.
  • Thanks Dean but there are multiple reference files (on my end) involved with submitting the print so you wouldn't be able to get the desired output display. Our SysAdmins are looking into it here but I appreciate your offer to help. I just thought I'd throw it out onto this forum to see if anyone had the same type of results as me. Thanks again.
Reply
