Printing in monochrome
Can anybody help me?
I need to print a PID from Micro station with maintaining the qualities below.
Whole drawing should be in black color on print, same time i need to highlight some isolation valves in red color.
I can't change all objects in the drawing to white and keep the valves in red. PID color must be remain there for the certain reasons.
I have tried with editing pen table, all pen color i defined as black except valves color. valve is colored with 3 (red) from the pallet, so in the pen table 3 defined as red only, but in the print some other color objects also coming in yellow green color.
I tried with monochrome option, then all goes as black, even though i changed 3 as red.
Can anyone suggest me what to do?
binoy
  • Hello Binoy,
    Odd that you get other colors than just red and black/white. An example of your files would be helpfull.
    Have you tried setting Level Overrides in your level manager to red for the valves and black for the other data.
    Provided your Valves are on a separate level, that could be an alternative.
    Your PID data will not be affected, only the display will change when you switch ON the Level Overrides in View Attributes.
    I hope this is of help.
    Best regards,
    Henk
Reply
  • Hello Binoy,
    Best regards,
    Henk
