Printtable not working
Hi!
I cannot get my lineweights to change according to the setup I have done in the pentable. If you look at the image, the thick lines are lineweight 4 and 5, and in my pentable they are set to print as 0.4 and 0.6. And also the lines from 0 to 3 all print with the same thickness. I have tried everything, from changing the pentable path in the Worrkspace>Configuration to see only the one pentable and then to attach it once inside the print dialog.
I am using the Bentley pdf writer also, but no success.
Attached also the pentable I use.
Sarel1.tbl
