When I create a PDF with the pdf.pltcfg I get a file that's 2.5Mb With printer.pltcfg and setting the windows printer to Adobe PDF I get a file that's 313 Kb. Both PDF files look and print the same quality. I have all the extra's turned off like bookmarks, engineering data, have no rasters, just many ACAD 3d reference files attached. What am I missing to create a smaller file to email with Bentley driver?
TIA
Terry Judy Jr.
MS SS2 08.11.09.357
GeoPAK SS2 08-11.07.536
Cook Coggin Engineers, Inc. - Tupelo, MS
TRJ-CCE:If you have Adobe Acrobat v8.0 or higher you can go to the documen pull down and choose 'Reduce File Size' to eliminate the white space. I know this wasn't available in v5.0 but it showed up when I upgraded from that to v8.0.
Unfortunately when you do this it doubles the size of the pdf file !!!!!!!!!!!!!!!!!!!!
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
Not sure if this will help but there should be a setting for resolution. Try changing it to 2.
(this is from the pdf.plt, This also should be int pdfpltcfg)
;------------------------------------------------------------------------------ ; Control printing permissions. Default qualifier is "1". Legal values are: ; 0 = Do not allow printing ; 1 = Allow high resolution printing ; 2 = Allow only low resolution printing ; Either the owner or user password must be set for this setting to be honored. CmdName /appname="pdf" /command="AllowPrinting" /qualifier="1" ;------------------------------------------------------------------------------
Also, try changing the quality to less than 100:
; The following record controls the quality of rasterized plots. ; The range is 0 < quality <= 100. The default is 100, which means plots ; are rasterized at full device resolution. Smaller values may be used to ; reduce rasterized plot file size. rasterized_parameters /quality=100
Just a thought. This may or may not work for you.
Roland
V8i SS4 v.08.11.09,829AECOsim BD V8i
