BORDER 100.dgn
The issue I am having this time arises from placing a fence on a border sheet and the border not plotting properly. I have a fence placed that states it is at 1.0000 scale, maximized and centered, the preview and the plot are not completely represented. The border that is used (in this case the red line) to set the fence is supposed to print (according to my seniors here) but many of the older prints (before I began working here) seem to be inconsistent on if the outer border is located or not. When I print, there is no right side to the print and ever since I changed the cell library to make the borders a factor of 1.0000 (they were .9###) everyone else prints with the same border edge being deleted. I have used maximize fence clip, changed the border to a smaller size both in and out of scale. I have made true the print border and print fence and made them false and came up the the same results.
The above is a screen capture of the print preview and the border on the right hand side of the topmost window is the preview screen. The edge of the fence is placed as a block over the border and three edges fall within the dotted fence representation where the right hand side has no border and the dotted line has no line on it or in it.
What could be some problems causing this and what are some options I could do to fix this?
efor_no0p
I am the "fng" around here and the civil engineering firm I work for has been entrenched in their methods for decades and still use v8 version...they dont like change. Mostly I am just trying to get the bordersheet cell I have created to print appropriately. After looking at a lot of older prints kept in the building, there has been a consistency issue with the plotting. I just want to get a method to place the fence (as per my underwhelming training has noted to do) and then print. I have another issue with scale while this is being brought up. When a file is opened and fenced my console states it is 100.0041 scale and my coworkers are closer to 100.4. My thoughts were it has something to do with the accuracy values for the workspace or a rounding issue as a floating int between the versions of microstation.
The outside border from your file is printing for me using MicroStation SS2 and the delivered printer.pltcfg. Can you attach the .plt file you are using. I believe you said the PDF.plt is producing a good PDF file, correct? I am aslo sending a video for converting the .plt files to .pltcfg files when you get ready to do this.
communities.bentley.com/.../7188.video-printer-driver-file-conversion.aspx
https://communities.bentley.com/cfs-file.ashx/__key/communityserver-discussions-components-files/19568/8712.RICOH240.PLT
This is the plot driver (named after the printer used).
I do not see a problem with the 8712.RICOH240.plt file. Can you send a private message to me with your contact information? I would like to contact you and set up a live meeting so I can see your screen. To do this you should be able to select my name in the post and select send private message.
message sent
