Design Scripts
Anyone know where I can find a good thread fully describing these? Here is what I am looking to do, maybe I don't need a design script and there is a better way of doing it.
I have existing elements on their respective levels in my profile. Right now they are on a 0 weight and "grey-scale" color. Our client might want this changed to non-grey-scale and a weight 1 down the road. Instead of going to all 50 plan & profiles and changing it back and forth. I would like to do something like (I dont know much about "coding" or anything mind you), levelname = color,weight,style.
Is there a way to achieve this quickly using a design script/pen table?
Microstation V8i Select Series 3
Bentley GEOPAK V8i (SELECTseries 3) 08.11.09.493 for Microstation V8i on Windows x86
OS: Microsoft Windows 7 Profressional
System Model: HP Z820 Workstation
System Type: x64-based PC
ProcessorL Intel(R) Xeon(R) CPU E5-2631 0 @ 2.30GHz, 2301 Mhz, 6 Core(s)
(RAM) 8.00GB
CAD User for 2 years
  • Yes, there is.  You can use either a design script or a pen table to test on these elements and then specify the output weight/color at print time.  What attributes separate these elements from all others beside weight=0 and color?  What index is the grey-scale color?  Also, do you want to test on all files (master and reference) or specific levels?
  • What attributes separate these elements from all others beside weight=0 and color?
    Level name, style. They are elements just drawn in the profile using regular v8i s3. They are in a file being referenced in.
    Colors 232-236 plot various degrees of grayscale/half-tones.
    PEN(1)=(0-255)/RGB=(  0,  0,  0)  ;BLACK
    PEN(2)=(232)  /RGB=(245,245,245)
    PEN(3)=(233)  /RGB=(215,215,215)
    PEN(4)=(236)  /RGB=(186,186,186)
    PEN(5)=(235)  /RGB=(156,156,156)
    PEN(6)=(234)  /RGB=(127,127,127)
    We use varying .plt(s) currently. This is the setting set up on all of them. I have yet to convert them to .pltcfg yet.
    I think for my needs for this and in the future, I would like to do it for specific levels. I have a level.dgnlib that we use to standardize what levels our jobs get. So if I can easily go to a job and have a certain "script" I can insert for how each different client likes to see the certain levels. That would be really useful.
    Thank you for the quick reply.
  • Using a MicroStation pen table will probably be the easiest method for you not being familiar with either.  In the Print dialog, select Resymbolization - New Pen Table.  Enter a name.tbl and select Save.  This will open the new pen table in the Modify Pen Table dialog.  A new section will be automatically added.  You can add other sections under the Edit menu.  There are two tabs on the right.  In the Element Selection Criteria, select the attributes you want to test on: Color ( enter 232-236), Level (select the Level item and a list of levels will be presented, pick the appropriate ones), Weight (enter 0).  On the Element Output Actions tab, check mark the color and take the default By Index 0, check mark Weight and select 1 from the options.  Save the pen table and attach at the bottom of the Print dialog or in Print Organizer.
    There is detailed information regarding Pen Tables in the MicroStation online help (Help - Contents) under Working with Complete Designs - Printing - Print Resymbolization and Pen Tables.
    Give it a try and let me know if you have any questions or problems.
    Answer Verified By: JROADS
  • Thanks Dawn! That worked for the most part. See Attached, everything I wanted came in at grey scale. For some reason, some of the leaders/leader heads did not make the transition even though they are on the correct level. Same with the text on the right side. I just grabbed all existing levels for the profile reference and changed the output color to 236.
  • In the pen table dialog, look in the lower left.  There is a Pen Table Options.  Try enabling Explode dimensions.
Reply Children
  • No that didn't work. Besides the text on the right, it seems to just be the arrowhead that isn't converting over to grey-scale. I tried printing a few other pages as well to the same effect. I do not know if this makes a difference, but we use a cell "ARRHD" to determine our Arrow Terminator in our Dimension styles.
    Under Pen Table Options --> Complex/Compound Element Options, I have everything checked. I have also tried both Element symbology comparison modes.
    In the main window of Element Selection Criteria under Class: Originally I just had Primary highlighted, I now have everything highlighted, still no effect. I have all Types highlighted as well.
  • I'm sorry but if your client wants you to change the elements to  weight 1 not  just printing so why not
    just use batch processor to make everything weight 1 in all your files,
    You said"" I have existing elements on their respective levels in my profile. Right now they are on a 0 weight and "grey-scale" color. Our client might want this changed to non-grey-scale and a weight 1 down the road."
    So why are you printing grey scale your client said non grey scale what does that mean ? colour  or B&W or WYSIWYG?
    While were here
    Go and make a new dgnlib file ( call it client name) with all your level names predefined and by level set to wt 1
    open a new seed file named it your clients name and import/ attach the levels from the dgnlib file. will now take care of all future works...
    Lorys
    click link to PM me
