[V8i SS3] Print Organizer won't print rasters (on my machine only)
I have set up a Print Organizer set that creates a pdf (using pdf.pltcfg).  For some reason with my PC it creates a pdf without the raster (small file size), but when the same PO set is processed on a coworker's screen, the rasters are part of the resulting pdf (large file size).  Both of us are pulling settings from a networked workspace.
I can use the same pdf.pltcfg from the standard Print dialog box, and the raster will pe printed just fine.
Any suggestions on how to get PO to print rasters from my machine?
