I have an exhibit that references a dwg that has an aerial photo in it. I did a clip mask on this dwg so that a blank space is created to show title text. When I print to pdf, the preview looks fine but the pdf has the whole raster showing. It is not honoring the clip mask.
Any ideas why this is happening.
Perform a test with "Enable Driver Clipping" set to False in pdf.pltcfg. Make sure the .pltcfg is reloaded after saving the change.
Answer Verified By: tomorner
