Is it possible to create a 3D PDF with a border?
Any help is appreciated.
Josh
Thanks for the link. I'm not up to speed with all of the technical terms so I'm not 100% sure if that article answers the question.
Incase of misunderstanding the image below should help.
I'd like everything outside of the selected element to print as 2D, like you would normally in a 2D model space, and everything inside the selected element to print as a 3D PDF. Almost like a 3D viewport in a 2D print space.
If that article answers that question then I may have misunderstood the terminology, please correct me if that is the case.
Answer Verified By: Josh WHEALY
Csaba Szabó
BURKEN Ltd.
Hungary
Carl,
Check these 3D PDFs, rotate the models and you'll see. The one made from 3D view is using the whole A4 sized page, while the other (made from the 2D sheet) has only a rectangular space that perfectly fits the models size.
I'm not sure it will work this way. How can I attach 3D PDFs or other, not-media-type files in this forum?
