Linked Excel Table Not Printing Correctly
I have linked excel tables in my dgn files. When I create the PDF file, the table looks fine as shown below (this is a screen capture of the actual PDF document)...
But when I send the PDF to the printer it prints like what is shown below...
Is the problem the printer, the PDF, the link itself?
TIA
Parents Reply
  • Unknown said:
    The best thing about bluebeam is 50% scale.. Did you find a way to print 50% scale in Reader?
    To print to 50%  scale an adobe pdf you need full version adobe acrobat not the free acrobat reader... then you can specify  any scale by entering the % to same size paper ..ie was created with A1 and print on A3 but at 50 % and not the fit  option but scale option.
    other wise if you have to use acrobat reader then print to to a paper size that is exactly 50% of the original print size created  ie  created to be A1 but  print on A3  and use  fit to paper but it may not come out exactly 50% due to margins  etc but worth a try especially if you have scale bars on drawing to measure with or true dimensions to measure with scale ruler on printed out put..( this was how I did it at last place I worked)
    At home I use  nitro pdf reader it  is free and  has option for percentage reduction to same size paper if your printer can handle the paper size then that option is available it also creates pdfs  out side of cad  ie msoffice products, emails etc I like it and its easy to use and has lots of great easy features...and again its free!
    Lorys
    click link to PM me
