Where should I save print styles for print organizer? I have created some print styles in my own dgnlib, meaning I have added my own folder to the configuration variable to look at my folder along with the company vars. But when I go to "Apply Print Style" I only see the one dgnlib list of styles I originally created and not the ones I put in PrintPrep.dgnlib. I thought I would have list from my orginal dgnlib and then the list from the newer dgnlib.
In looking at the variables it looked like the only place that used dgnlib's was the User Interface DGN Library List & the DGN library List. I'm probably wrong seeing as I only see one set of print styles available.
What am I missing?
Thank you
Creating Print styles in a DGNLIB and add the DGNLIB file to variable MS_DGNLIBLIST.Variable MS_DGNLIBLIST requires a file name like: <PATH>\*.dgnlib !!Just filling in a directory name is not enough.Secondly: After changing variables, restart MicroStation ( I bed you have done that already :-) )Hope this helps
