In SS3 using pdf.pltcfg, the gaps are disappearing on some linestyles.
The line/gap patterns are defined as : LS=2, 1.75, 1.05 mm, LS=3, 4.2, 2.4 mm, and LS=5, 1.4, 1.4 mm. As shown below, the linestyles with smaller gaps print solid. The print preview looks as expected, but the results are not. Is there something about pdf.pltcfg that causes this? Is the only solution to increase the gap sizes?
Have you tried to change the LTScale this will make the gaps bigger as well as the dashed lines... by default they are 1 ...
what print scale are you using ?
Lorys
