Export all views to pdf (one package/file)
Ok so in AutoCAD, you can create your drawing in model space then set up layouts that already have your border/title block informationthat you have set up pre and bring in viewports from your model space and annotate those viewports. After all drawings are complete, there is an "Export" button in the file menu. There are several export type options such as "Export to PDF". There are many variable within this feature that also include the option to export all layouts into one pdf.
My question is, can Microstation do this? I have several sheets set up. I also set up the file in Print Organizer to show my sheets. I can select all sheets and print to pdf, unfortunatley these files come separate and not in a file package that I need.
Here is a link to see what I am talking about. www.cad-notes.com/create-pdf-from-autocad-drawings. See the section EXPORTPDF.
