Hi
I'm having trouble applying styles to my file set of drawings in the print organiser.
I have about 40 drawings, and want to apply different print styles to some of those drawings. So I'll have about 20 with one print style, 10 with another, and 10 with a third print style.
However when I do that, the print style I had already applied to the first lot of drawings gets messed up. Is it impossible to apply different print styles to one file set of drawings?
Make sure none of your Print Styles are set as the Default (black checkmark)
My test results are:
A Print Style applied to a higher folder in the hierarchy will change properties of print definitions in all sub-folders. However, when applying a Print Style to a sub-folder only the print definitions in the sub-folder should be affected. In the example below:
-A Print Style applied to the Untitled folder will affect all print definitions in all folders.
-A Print Style applied to the 2 folder will affect print definitions in the 2 and 3 (sub-folder under 2) folders.
-A Print Style applied to the 3 folder will affect print definitions in the 3 folder only.
-A Print Style applied to the 4 folder will affect print definitions in the 4 folder only.
Here's an image of the PSET folder arrangement.
The files that get messed up get random properties, not based on the new styles I'm applying to (the other) files.
