I can print only rasterized PDF, when I try print "un-rasterized" MS always go to error. Where can be problem? I run on Parallels W8.1 4 GB RAM, I thought that and here is problem. But I try clean BootCamp install W10 + 16 GB RAM and situation is same.
I have this problem, when try print Sheet - from some my files (...but directly this file I can't provide to 3rd side - I understand that can be problem, to solve my problem). Model was printed succesfully.
ADDED:
I found that problem is in DGN from architects, if I have attached this file and want print, it always crash - except one - raster print, this work - but only raster and PDF. Now just find where is problem in DGN from architects... Now I found, that is same problem like here: http://communities.bentley.com/products/microstation/microstation_printing/f/19568/p/109836/336291#336291
