Why are Level Symbology Overrides ignored when using a Design Script with Microstation
I am trying to use a Design Script in MicroStation, and I can't get it to look at my level symbology overrides. For instance, If my design script calls for all elements that are color=0 to be screened, I want to be able to use level overrides to set other elements to color=0 (without having to actually change the element color). It appears that design scripts ignore the symbology overrides and process the element based on its actual color.
I read somewhere in these forums that IPLOT users can set a variable to allow the design script to treat the elements based on symbology override values:
IPLOTSRV_DESIGN_SCRIPT_SYMBOLOGY_AS_STORED determines whether or not level override symbology is taken into account in a design script.
I was wondering if there is a similar variable that would do the same thing for MicroStation printing (not in IPLOT).
Chris
