Does anyone know how to write a macro that will automatically place a fence around the border of the drawing and print a specific drawing size to pdf? I'm not very code savvy and I didn't see anything already covering this. Thanks.
Hi Vince Depending on how your drawing(s) are setup, that option is part of Print Organizer. This is MicroStation's Batch Plotting utility (File > Print Organizer). have you looked at Print Organizer?
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Hi Vincent :
Here is a good overview about Print Organizer by Dawn Clark.MicroStation V8i Print Organizer - Getting Started Guide
Regards,Leonard Jones.
Rod WingSenior Systems Analyst
RodWing, how can I get the Microstation Print Dialog to pull in all the settings from the print style? When i go to the print dialog>settings>Apply Print Style only the Driver, paper, pen table and Design Script are set via the print style settings. I have defined the print style to grab a shape on a specific level to use as the fence and it works well in the Print Organizer but just not in the single sheet print dialog. Any ideas?
