I am working on a new workspace for my company and have encountered a problem with print organizer not using the fonts and linestyles that are called for in the workspace. I am using the correct pcf. The dgn looks correct on the screen and when I print a sheet through the print dialogue it looks correct but when I print it through the print organizer the fonts and linestyles are all wrong.
I have compared the loaded resource files through Configuration Explorer. The new and old workspaces are loading the same files from the same directory. I have attached some images below to help.
Relevant software and OS:
MicroStation: 08.11.09.459 (does not change from one workspace to the next)
Windows 7 Professional with service pack 1
Jason
The image above is wrong
The image below is correct.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Answer Verified By: Jason Brame
