I am working on a new workspace for my company and have encountered a problem with print organizer not using the fonts and linestyles that are called for in the workspace. I am using the correct pcf. The dgn looks correct on the screen and when I print a sheet through the print dialogue it looks correct but when I print it through the print organizer the fonts and linestyles are all wrong.
I have compared the loaded resource files through Configuration Explorer. The new and old workspaces are loading the same files from the same directory. I have attached some images below to help.
Relevant software and OS:
MicroStation: 08.11.09.459 (does not change from one workspace to the next)
Windows 7 Professional with service pack 1
Jason
The image above is wrong
The image below is correct.
Hello Todd,
We are having this problem again. We had it fixed once now it is in the PW Workspace. Do you have any ideas about PW as you asked about that at the end of your message. Thanks.
David Sullivan
Engineering Software Support Engineer
MS V8i SS2 v08.11.07.492
MS ORD-CE v10.09.00.91
Mr. Sullivan, Here at ALDOT we have had a similar issue after installing ORD. In those cases I have found that the print engine gets set to ORD. I go thru the motions of setting the iplot engine back to v8i and it works as expected. You do this thru the ProjectWise InterPlot Organizer Configure dialog on the local machine. I have not yet tested it yet to see if there is a problem if ONLY ORD is installed.
