I started to edit a pltcfg. I wanted to manipulate the widths so I went to Edit Printer Driver Configuration>Weight Maps there I was a bit surprised when instead of seeing "in." or "mm" I saw "dots". It starts off @ 1 dot for 2 design weights and goes to 16 dots.
I haven't seen this before. I would like more distinction between each design weight, closer to the image on the right. And since I'm here maybe someone could educate me as to what "dots" refer to.
Thank you
Answer Verified By: Dbl J D
I believe dots may have been the only supported pen width unit back around MicroStation/J, via the old .plt weight_strokes line. It continues to be the default unit if weight_strokes doesn't specify inches or millimeters. Every .plt and .pltcfg delivered since at least MicroStation V8 XM has specified pen widths in millimeters, with the last use of dots occurring in the 2004 Edition raster and PostScript .plt files.
