Setting a reference transparant works just fine on the screen, but when I try to print a drawing with a transparant reference this isn't working.
I have the 'Rasterized' checkbox highlighted.
In V8i Series 3 this worked without much trouble. All we had to do was highlight the 'Rasterized' checkbox. But when we updated to Connect this wasn't working anymore.
Anyone has a solution for this problem?
Thanks in advance,
Thijs Paus
Kroeze Interieurbouw
Netherlands
It's been a few years. But does anyone know if there is a way to set this to be enabled automatically by default on reference attach?
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hi everyone,
This is quite not an satisfying solution. It worked well in V8i. printed as seen on screen.
And "References > Properties > Adjust Colors, make sure “Print Adjusted Colors” is enabled" is not possible to set for live-references in 2nd or deeper layer.
I hope there will be a fix for this.
cya
Volker
Hi Admin JKP, I managed to print live references with transparency in 2nd or deeper layer. You have to fill in the nesting depth in "references"
